Author Topic: 500 classic EFI  (Read 1787 times)
brunoespinha
on: November 16, 2023, 07:22:37 pm
my motorcycle's engine or gearbox is making a noise like something is loose. a clacking kind. I can't tell if it's coming from the engine or the gearbox. I've never put oil in the gearbox because the manual doesn't mention gearbox oil. Does anyone have any clues?
axman88
  • Vintage Motorcycle Fan
Reply #1 on: November 17, 2023, 03:40:23 pm
If you can make a sound or video recording and post it online at a hosting side, (perhaps Gyazo?) that would be helpful.
Also, posting in the section for UCE will probably attract more response than here in technical reference.
Is the frequency of the "clacking" in time with ignition events, or much lower?
AzCal Retred
  • Chennai Wrencher
  • a journey of a thousand li starts under one's feet
Reply #2 on: November 17, 2023, 10:33:08 pm
Don't forget to look at the primary chain & tensioner.
A trifecta of Pre-Unit Bullets: a Red Deluxe 500, a Green Standard 500, and a Black ES 350.
James.
  • Independent.
Reply #3 on: November 20, 2023, 04:20:29 pm
I had that type of noise.It was the pushrod cam follower bearing that was worn.I had it replaced under warranty on a 2 year old 4k miles classic 500
Freedom.
James.
  • Independent.
Reply #4 on: November 21, 2023, 09:36:14 am
I am assuming you have checked your valve clearances.
Freedom.
Crabsapper
  • So many experts......
Reply #5 on: November 21, 2023, 06:41:15 pm
The 500 EFI has hydraulic tappets.
James.
  • Independent.
Reply #6 on: November 23, 2023, 11:47:03 am
So it has.Forgot about that.
Freedom.
  • There are no truths outside the Gates of Eden
Reply #7 on: November 24, 2023, 11:57:17 am
      Don't your engine & gearbox share the same oil?
Richard230
Reply #8 on: November 24, 2023, 02:20:22 pm
If the engine is a UCE EFI, it sure does.  ;)
2018 16.6 kWh Zero S, 2020 KTM Duke 390, 2002 Yamaha FZ1
