I have a 2020 Bullet 500 Trials Works replica.
The bike has less than 1000 miles on the odo and I'm having fueling issues. The fuel pump doesn't come on when the key is switched on and the kill switch is in the run position. Yes, the side stand is up, the fuse is good but I replaced it with a new one just to be sure. I found the connector for the fuel pump, separated it and check for current. The battery is showing 12.8 volts but with the key and handlebar switch in the run position, the pump harness connector only shows .05 volts. I removed and cleaned the relay terminals and plug but it made no difference in the voltage readout. The multimeter is set for 20v DC.
Any suggestions other than "try the kickstart" are welcome.
Thank you
