Focus, focus. The Yamaha product is a carb cleaner concentrate. You have a carby bike with plugged pilot jets, spiders in the bowls, etc. mix the cleaner 50-50 with water. Use a syringe or squeeze bottle to fill the carb(s) ON THE BIKE. let set a few hours. Drain the goop, flush with clean fuel, start bike. If it's not fixed, it's better. Repeat. It's fixed! Carbs clean as a whistle. Been around since the late 70's. In the old days. It was to be mixed with fuel. Reformulated to be mixed with water, it works even better! I can almost bet your Yamaha dealer never heard of it. We keep it in stock for bikes trailered in when people say "make run". You can also soak carbs in it when you are rebuilding them to clean them like new.
