Author Topic: What did you do to your Royal Enfield today?  (Read 1584729 times)
0 Members and 3 Guests are viewing this topic.
LJB
Reply #8265 on: October 06, 2022, 02:59:39 am
Rode it a bit faster than normal...
https://youtu.be/SKedsI0QWyc
Callic 350 - 2020
WnRn
  • 2011 C5 500 Classic "DugDug"
Reply #8266 on: October 19, 2022, 12:25:06 am
In the pursuit of making DugDug look older that it is old new side boxes fitted to both sides. The black looks more old style to me.
 Shame the pinstriping and sticker are not in silver to match the decal on the tank.
The chief enemy of creativity is common sense (Pablo Picasso)
Roadie
Reply #8267 on: October 29, 2022, 12:29:44 pm
Cool looking bike Wn Rn. Very neat
WnRn
Reply #8268 on: October 29, 2022, 09:13:54 pm
Thank you. Still a few more things to do.  ;D
WnRn
Reply #8269 on: October 30, 2022, 06:47:48 am
Added thick wall alloy handlebars and rubber old style grips. Less vibes? Not really as it is a 500 single.  ;D
Made a sidestand foot from the top off an oil filter wrench and then an old round bar end mirror. 10mm hole drilled into the foot of the sidestand to hold it all together. Works ok in sand. Better than the standard sidestand.  :o
DugDug sticker.
Kriega saddlebags.
oldphart
Reply #8270 on: October 30, 2022, 07:52:21 am
DugDug sticker.
Kriega saddlebags.
Nice.
Is that sidestand foot on a pivoting head so regardless of the angle of the ground, it sits flat?
Grandpa Slow
2021 Classic 500
WnRn
Reply #8271 on: October 30, 2022, 10:33:36 am
Nice.
Sits flat.
  • Stuck here in RI with the Memphis Blues again
Reply #8272 on: October 30, 2022, 02:28:49 pm
       Your bike has the same crappy side stand as my '08 AVL. I'd have thought Enfield would have put a decent one on by now, but it all comes down to save a dollar per bike. And I can't blame them.
        Mine is "OK", but it's tinfoil compared to what I'm used to. Don't trust it on hot asphalt or medium & fine sand.
Crabsapper
  • So many experts......
Reply #8273 on: October 31, 2022, 05:38:18 pm
Converted my Tribute to carburettor.  :)
Haggis
Reply #8274 on: October 31, 2022, 07:50:54 pm
Looks good.
I have an Amal conversion on one my efi 500.
Not seen a euro4 with the conversion before.
Does the cv carb have the throttle position sensor fitted?
What have you done to keep the mil off because of missing injector?
« Last Edit: October 31, 2022, 07:54:16 pm by Haggis »
Off route, recalculate?
Crabsapper
Reply #8275 on: October 31, 2022, 08:36:51 pm
Looks good.
Thanks.
I've fitted a wiring loom from a 350 carb bike  complete with Ammeter and TCI unit, so no MIL to worry about. Also fitted stator and rotor from the same bike.
The CV carb does have a TPS sensor that plugs into the TCI.
The Euro 4 bike has a couple more sensors and ABS to worry about, but I've already deleted my ABS.
trud
Reply #8276 on: October 31, 2022, 08:40:57 pm
Converted, but what for?
B5 2013
Crabsapper
Reply #8277 on: October 31, 2022, 08:57:45 pm
I don't understand the question.
WnRn
Reply #8278 on: October 31, 2022, 09:16:44 pm
I converted my C5 to Amal carb from EFI because the bike came with an after market muffler when I bough the bike. It would not run correctly. To fix it was either a Power Commander or Hitchcocks Amal conversion. Went Amal because it was cheaper than a Power Commander and dyno to set up the EFI to match the muffler. Plus I prefer jets and needles than electrons.
oldphart
Reply #8279 on: November 01, 2022, 05:13:14 am
I lifted the top of the bike cover to get rid of the rain that had pooled in it - yes, it's been that sort of weather.
Grandpa Slow
2021 Classic 500
