For the folks looking at the unavailable Jawa Perak - here's a liquid cooled
320cc twin cylinder 5-speed machine for under $3K, sold as a 250...?!?! Is this the CB350 Honda for the 2020's? Not California legal though...but maybe when filtered thru Arizona/Texas with 7500 on the clock...? Honda made its new CL500 by jacking up the rear end of the existing 500 Kruzer about 3". A pair of longer shocks, some trials universals, relocate the footpegs & controls and you are there, a do-it-yerself CL350. Except EFI and liquid cooling.
They also have a few (non-Cal) machines that use the new Zong Shen EFI'd 6-speed 250 single (TITAN 250 EFI - Manual 6 Speed).
https://www.vitacci.com/motorcycles/cruizer-250/Model
Cruiser 250 & GTO Complete Vehicle Length * width * height mm 2225*850*1140
Wheelbase mm 1480mm
Kerb weight kg 185kg
Rated load kg 150 kg
Max. speed km/h 130km/h
Brake type ( Front / Rear ) Double Disc / Single Disc
Brake Operating ( Front / Rear ) Manual / Foot Brake
Wheel Rim ( Front / Rear ) Aluminum wheel
Tire size ( Front / Rear ) 120/80-17 、 160/55-17
Identification / Type
2 cylinder, 4 stroke, Water coolingElectronic EFI
Bore × Stroke in mm:
62 mm × 53mm (320cc; 2@160cc....??)Compression Ratio 10.5 :1
Rated Power kW/(r/min) 16.2kw/7500 rpm
Max. Power kW/(r/min) 17.5kw /8000 rpm (24hp)
Max. Torque N · m/(r/min) 24.7 N.m /5000 rpm
Mini. Idle Speed r/min 1300 ± 100 rpm
Mini. Fuel Consumption (l/100km) 3.58 L/100km
Fuel Type RQ-93
Lubrication Forced lubrication
Lubricant Type SJ 15W/40
Clutch Type Oil-bathing multi-plate clutch
Starting Electric start
Transmission Ratio Primary: 3.632 Terminal: 2.256
Successive transmission ratios:
1st: 2.846
2nd:1.778
3rd:1.333
4th:1.083
5th:0.913
