On a tangent, ”pre-load” is an unfortunate misnomer when talking about forks under load since it does not increase the force on the spring when the fork is actually loaded (by the weight of the bike and rider). It just changes the upper contact point of the spring and adjusts the position of the upper fork tube under load (sag). Changing the length of the spacer tube does exactly the same thing. The only way to make sense of ”pre-load” as ”increasing the load on the spring” is when it is unloaded (before any load). When you increase the length of the damper rod, you increase the pre-load from below by changing the position of the lower contact point of the spring (which is connected to the lower fork leg), thereby increasing the compression stroke as the upper fork tube is lifted upwards (if and only if it is loaded). The rebound stroke will remain the same and in order to distribute the increased stroke evenly between compression (downward) and rebound (upward), we need to lower preload from above by shortening the spacer, get a shorter spring or use our preload adjusters. Phew.
/Kranis
