If you know of my other Iron Barrel Build, nothing really stays the same for long. I chopped the rear hoop off. Shortened it. TIG'd it back on.
Hoop chopped.
Shortened and tail light mounting section. Bit of flat bar with stainless weld nuts behind it. Got all dressed up and smoothed off.
Tail light trail fit.
Fully welded out with the TIG and started to scribe out the guard. It will sit tucked up under the seat and flush with the inside of rear hoop.
The seat mount cross member bracket was also relocated and I actually corrected it's dimensions. It was 2mm out of square and 3mm difference in height left to right.
Thats enough for a Sunday. More to come soon.
