Back on with it.
17 tooth sprocket on the front. Fresh oil and filter and everything checked and re-set.
Today was a RDO so I took the opportunity to get out and really give it a good tune targeting specific throttle areas and AFR targets.
I took a more methodical approach. Very much the same as I'd tune a carburetor and it yielded excellent results!
Lowering the front sprocket from a 18 to 17 was a good improvement. Took the load off the engine and at highway cruising speeds it feels very effortless. With the 18 it felt it was laboring just a little bit.
The bike still reached "the ton". Just got there a little sooner and revved out more compared to before it couldn't quite get to redline.
To know I was in the correct throttle position. The program displays (when the key is on) where the throttle is positioned.
Which I marked on a piece of tape on the throttle housing with all the target throttle percentages.
Each time I headed out I'd make multiple runs at a target throttle range from as close to idle as possible in a few different gears on road conditions.
#1 Run : Targeted the 60,80 and 100% throttle ranges with a target AFR of 13.2 to 3000rpm, then gradually richening up to 12.8 in the higher rpm ranges.
#2 Run : Targeted the 15,29 and 40% throttle ranges. These are typical cruising ranges. AFR target was at 13.2 for most of this area and 13.3 on the highway cruising rpm (3250,3500,3700) then set to 13 AFR from 4000rpm and higher.
#3 Run : Targeted the 5 and 10 % throttle ranges. These were 13.2. Mainly in 1st, 2nd and 3rd gear pulls at these range to try get the bike to rev as high as possible. Which was around 4500rpm.
#4 Run : Targeted the 2% column. Basically 1st and 2nd gear little pulls in a quiet area in my local industrial estate.
I didn't touch the 0% column. That would be set so there won't be any lean popping on over-run.
This is the end result. No big rich spikes in any cells which was from the bike on over-run (lean) and the auto-tuner trying to correct it by richening cells from previous tune runs.
It feels very crisp all the way off Idle now. There's no dull spots and has a very nice strong, smooth linear pull to 3500rpm then it really starts to sing all the way to 5000rpm.
After todays Session Vs Hitchcocks Base MapVs Autotune Targeting all cellsThe 40,60,80 and 100% areas haven't changed all that much. But the main improvement was the smaller throttle opening percentages. The response is a lot more crisp and no weird spikes due to over run.
Targeting and tuning to only specific areas made it tune a lot quicker. You could feel the change after a few pulls until no more change was felt, then on to the next range and so on.
Comparing the base map to my new tuned map. It seems to have taken fuel away in areas. My tuner informs me that is due to the combustion being more efficient in those zones due to the modifications.
Here's plug looking healthy. Running a colder BPR7ES due to the raised compression ratio. Next will be a iridium.
So in all that. I'm very happy with the result and how its running!
I'll fiddle with a few more 60,80,100% runs. But that has to be during "quiet" traffic times. Haha
