Parts are streaming in by the day, got things narrowed down and I believe I have a plan of attack. In no particular order: Looking like re-phasing the stock cams (thanks for Ace's work) my lift measures .308 on both lobes w/possible advanced? 3-way timing pinion (will check cam timing naturally beforehand) a Robbins .040 over 9:1 piston (piston weight 401g/ pin weight 103g) on a fully polished HDA alloy rod (332g) pumping in a 500cc alloy barrel (I want a barrel I can do re-bores if needed so will sacrifice the added cc benefits) carefully ported head (woked over throat, short side radius and valve guide boss streamlining) with Hitchcocks competition valve kit, stock steel rocker blocks machined to accept "modified" Samrat rocker arms, blocks will be raised .250 via plates which combined with the rockers actual ratio measurements, should yield about a 1.313:1 ratio for a tick over .400 lift and will utilize Hitchcocks 6mm longer alloy pushrods that will basically keep the same geometry from the lifters to the rocker pushrod ends. No pushrod clearance issues with the passages in cylinder or head. Essentially the valve side of the rocker arm will just be longer, have longer reach of an additional 5/16" (.3125) based on my figures (the existing rockers are not exactly 1:1, closer to .980 on the valve side, exact figures yet to be determined) FAG X-lite bearings, existing hi volume oil pumps, 1 3/4 sweptback exhaust w/Goldstar Silencer, Mikuni 34mm VM carb and for now the reliable points ignition. Really wanted to go with the coated ligtweight Ace piston, Carillo rod w/bronze bush and really like the rockers offered but funds just aren't there
Here's a few shots with the rocker blocks in preliminary stage mock-up (soft alloy Samrat blocks will not be used) yet to machine steel blocks, brazed/welded custom ground rocker arm tips etc. Just what I've gathered so far, just for the sake of anyone interested in what others are doing ......nothing ground breaking, or new, just trying to build an engine that will handle speeds up to 80mph or so with the capability of short blasts beyond that, and doing things on what has turned out to be a shoe string budget
