Royal Enfield Motorcycles => Vintage Royal Enfield => Topic started by: '45 WD CO on April 22, 2013, 05:28:01 pm
Thought my WD Enfield was a '45, but have been informed by better sources that the frame and engine numbers declare the bike to be a '43. Lucky me! Anyhow, I'm having a difficult time keeping the carb in a well-running position (air screw, idel, choke). The bike had not run in 13 years, so I completely cleaned the carb, installed new fuel lines and relined the fuel tank, and then she ran very well, although normally always needing a bit of choke. Recently, though, sometimes she gasps for either air or fuel and then dies and is a bair to restart, while at other times she runs just beautifully! Any suggestions? Does the amount of octane in the fuel make a big difference to these old bikes/carbs? Has anyone ever changed the carb from the original pre-monoblock to a concentric? Would that help?
Thanks! Bill
That might be an ignition problem. I thought I was having carb problems too. Turns out the magneto was bad and started firing on only 1 cylinder. Pull your spark plug and make sure your getting a good solid blue spark before chasing the carb any further.
Interesting!!! It's actually a very poor spark and always has been! I've filed and cleaned the points, but would like to replace them, but can't find a pair yet. Hitchcocks seems to be out for the time being. If it's not the points, though, how do I determine it to be an underachieving magneto?
Thanks, Bill
Thanks, Bill
I forget exactly how to test it, something to do with wrapping a bare wire around the mag body and grounding out the other end. But what you are experiencing is exactly what the indications for a failing mag. Hard starting, not running after being hot and inconsistent spark.
I personally just ordered a Thorspark electronic ignition kit off of Ebay. It's designed to solve the problem of constantly failing mags. It's very easy to install and has a five year warranty. It has 2 electronic triggers that replace the points plate in the magneto, you don't need to remove the magneto at all to install it.
Problems with points usually lead to the condenser (capacitor) being leaky or just plain bad. I don't know much about the old war department models. so I cant help much with the ignition on them. I do know that Lucas used wax paper in their old condensers and they weren't known to last long especially with high temperatures (the wax melts).
