Author Topic: meteor carrier hardware  (Read 510 times)
Mike flanagan
on: March 17, 2024, 09:54:13 pm
could someone check the carrier hardware specs for the Meteor minor ,63,apparently ordered the wrong size.Many Thanks
Lorenzo
Reply #1 on: March 18, 2024, 12:00:35 am
Hi, Mike -
What do you need to know, exactly ?
As far as I know, the part no. for seat/mudguard carrier is 42270 for late MM with 17" wheels, and is the same part as fitted to late Bullet or Clipper 350.
If you need sizes of any part of this, I can measure up the carrier on my own Bullet 350 for comparison.
On the other hand, if it's fastener details only you require, the four muguard to carrier screws are pt. #10142, which according to my notes are 5/16" x 3/4" x 26 tpi - CYCLE rate (BSC / CEI). Seat bracket to carrier screws are 5/16" x 11/16", also cycle thread.
Have you made any progress with dismantling the forks ?
« Last Edit: March 18, 2024, 12:14:47 am by Lorenzo »
Mike flanagan
Reply #2 on: March 18, 2024, 12:46:18 am
everything is apart except the tubes and lowers.They are locked solid.I bought separate lowers and im trying to find good tubes.At least I know my M.M front is like the Crusader sports now.
Mike flanagan
Reply #3 on: March 18, 2024, 12:52:12 am
5/16,26tpi,3/4 doesn't  seem to be the correct size,btw.
Mike flanagan
Reply #4 on: March 28, 2024, 01:15:48 am
yes,i sourced use ones.i will continue soaking the tubes to separate lowers for later battles.
