This came up at the top of the list when I Googled "Anodize":
https://www.wikihow.com/Anodize-AluminumAs stated in the DYI instructions, it works very well for aluminum.
I also thought the recommendation to test it with an older offspring might work well (as a discipline measure), too. Give 'em a taste of what it could be like in prison.
Anodizing and Alodining serve the same purpose: Corrosion protection.
While Anodizing is a chemical process that coats and changes the surface molecules, the Anodizing process is electro-chemical.
I'm already familiar with the Alodine process. Did a lot of that with Bonderite 1132 working on the Gulf due to the salty humidity. Color selection is limited, though it is available in Clear and food coloring or other dye could be added I guess. I'll need to get some and test it with coloring.
(Interesting: On the Google search results page the sidebar has a link to power supply for "mere" $224!
It's exactly the same PS I got for under $50 on e-bay. Maybe I should make a label with a fancy name and sell mine for $224. A $175 profit ain't bad at all.
