Hello!
Yeah y'all really go wild, I'm just trying to show others my process for mounting this mikuni carb kit I picked up from hitchcocks.
That being said, I've hit kind of a snag. It seems that the cable they supplied with the kit is too short. I'm having my moto mechanic friend come over to confirm this.
Stock VM32s need about 85mm of cable outside of housing to function, according to mikunioz. I think this is on a single pull throttle setup without buttons etc, but I could be wrong. The cable they supplied came with roughly 100mm of cable outside the housing, shown here:
When installed on the carb this only leaves about 10mm of cable to attach to the throttle:
As we know, the stock setup for the throttle body is a push/pull setup built into the right hand controls. I'm trying to keep my controls stock, as they work fine. You can really use either hole, but each one I try puts too much tension on the cable and raises the slide. To clarify, all of the cable fittings on both the carb and cable itself are totally tight. It has as much open cable as can be had. Here are the holes I'm talking about:
I've played with the routing and there doesn't seem to be any pulling on the housing the way I currently have it routed. Granted I'm sure there's the normal amount of pull going from full lock. As it stands I'm talking with Hitchcocks about it, but it seems like this is indeed the length they send out with the kits, there wasn't a mess-up there. I'm just not entirely sure they mounted it to the stock throttle tube. I also know these mikunis are somewhat new for them, as previously they offered amal carb conversions. I also noticed the carb they sent is somewhat different than the one pictured, mainly because the choke lever is swapped.
Any thoughts here? am I missing something dumb? If they can't get me a cable that fits I'll just make one, but soldering is a pain.
