From his own Forum and postings here it's abundantly clear that 'Viczena' clearly understands all of the arcane workings of those electronic fripperies in a way I never shall. When considering any prospective "new" ride I am always happy to learn it is carbureted, and if I owned a UCE Bullet or Conti and its EFI or related systems gave me the least concern, I would be another prime candidate for a Hitchcocks carb conversion, likely preferring an Amal Concentric setup since I've had several, and could likely break down and reassemble them blindfolded, like in Army bootcamp. I'll concede that I'm a bit of a Luddite where all this is concerned. But gravity always works, and it seems that 90% or more of the woes that afflict UCEs have to do with some electro-farkle or other acting up such as fuel pumps or ECUs or the host of other sensors or gimcracks utterly lacking in my "primitivo" Iron Barrel. I lack 'Viczena's' obvious divinitory talents for interpreting ohmages and Amperes, and frankly just don't care to learn them. If I can't fix it with some spray carb cleaner and an air hose, I'm just not interested. On the flip side of the coin, I do recall an earlier thread posted here by someone who'd wanted to "upgrade" their carb to EFI--either an Iron Barrel or an AVL, I seem to recall...though it might have been a Himi or even a home market UCE, both of which came in both EFI and Carby flavors yonder and in some non-US export versions. At the time I'd thought, "Why the hell would anyone want to do that?" I mean, why would you want to replace a perfectly adequate fueling system that one can replace for like $24 brand new with one so prone to gremlins, where, if the least little hiccup occurred, you'd be looking at maybe a couple hundred bucks worth of prospective fixes? For a pony or three more at the throttle? Not for me, thanks.
So, I well respect anyone's choice to fuel their ride any way that works for them. I also doubt a well done carb conversion would harm resale value, at least here in the States. If anything, it might increase it as a "reliability enhancement". Of course, in Germany, with those white lab-coated TüV (vehicle inspection) guys peering into your ride's every nook and cranny seeking those Unzugelassenheiten ("unapprovables"), your mileage (or "kilometerage"?) may vary. I doubt many American cars, even some fresh off the lot, would squeak through a German vehicle inspection. So, that's the demanding current in which our man 'Viczena' is swimming.
