If you haven't cracked open the carb for a good cleaning of its bowl and jets, that might be a good idea, seeing as how long it's been sitting. Or, seeing as how you're already at least getting
some life out of her, you might just try
"The Sea Foam Shortcut Purge":
- If it's more than a month old, empty whatever gas is in the tank
- Dump in about 2/3 of a bottle of Sea Foam
- Turn the fuel tap onto "On" (not "Reserve")
- Fill fuel tank with nice fresh gas, turn off fuel tap, and come back tomorrow
- Fire her up and commence running through that tankful, and when you tank up again pour in the remaining 3rd of that Sea Foam
If you're already getting any life out of her at all, then that initial stronger concentration of Sea Foam and gas marinating in the carb bowl overnight will likely loosen up any cruds just enough for the rest of the more dilute Sea Foam to rinse them away pretty well. Don't be alarmed if there seems more white exhaust smoke than usual. That is normal. After the Sea Foam purge treatment, an ounce or two of Marvel Mystery Oil with every fill up will serve to more gently keep the innards clean. It's also a great dessert topping!
This Sea Foam overdosing thing is a pretty well known "easy fix" for irritable-running bikes, especially after a long winter layup. Berry's Chemtool B-3, Techron, or similar fuel additive solvent-cleaners might also do the trick, but Sea Foam's most often mentioned as the cure for those laid up cloggy ethanol-spew blues, which sounds just like what you may be dealing with.
