Not to get off track but back to the original question........
how does a K&N compare to a DNA filter? a K&N here is the US is less than a stock filter. They've been the performance standard here for years. plenty of BS is standard here. That alone doesn't mean anything but they are readily available and cheap
I do not have hard data about it, but K&N is known to make quality products, so the filter is probably not going to disintegrate and end up in your cylinder. It boils down to the media they use for filtration, which is usually oiled cotton, the same as DNA. IMHO it will work the same.
The fly in the ointment of all this performance topic is that nobody has any hard engine data. We would like to know what we have to work with.
When I was doing the RE singles over the past 12 years, I always posted up the head flow charts over the entire lift range with direct apples/apples comparison of stock vs ported using the same flow bench for accuracy. I always posted all the cam data for the cams we made. I always gave the critical info on the pistons and their bore clearance data, etc.
Nowadays, all I see is somebody throws parts out there with little or no info, maybe even from different makers who don't know what the other makers designed for, da da da da da da....
We always built matched systems that were made to give specific results together, and were tested and dynoed before anything hit market, and we gave unlimited tech support to customers free of charge.
I would love to see a stock head flow bench test at 28"H2O, and some real cam data and piston data.
My mentor and friend was Joe Mondello up until he passed away. I still have a lot of contacts in the biz. I can get pistons and cams made, and headwork done, etc. I have plenty of engine design experience, and even have designed complete billet heads for RE singles.
I'm semi-retired now, but I'm not dead.
The reason we do not see this data is there are plenty of copycats. You know shops cannot bill the time spent engineering a head to a customer, they need to split the cost between many people. Nowadays anyone can have access to 5 axis CNC mill, and there are quite some people that will just steal your work. This is why that data does not appear anymore. I am a software engineer, i do not even work in the field of mechanical engineering or engines; this has been my hobby for 25 years. And yet as a hobbyist I can get my hands on that (and on some 3d scanner. we scanned a hand made, well prepped head, had it slightly modified to get equal chamber volume and port section, then sent a stock head on the bench to get it milled. It worked, not massively better, but better nonetheless).
You know there are 2 ways to go about it. One that does not lead to great results, consisting in throwing parts and hoping it works. It is the one that makes aftermarket parts maker and small shop live. On the other hand, it is what allows them to build highly tuned engines... Building an engine costs a lot of money, which not everyone can or is willing to pay for. So people pay for some performance dream with a silencer or air filter, and the promise it will make more power.
The other way is to spend the time and money to really build the engine. It took me and a very competent friend nearly 2 years of research, work, trial and error to build my car race engine. We wasted 2 heads in the process and an engine block. But it is done. to my knowledge, there are less than 10 of these engines that have been pushed reliably that far or beyond, worldwide. Emphasis on reliably. For 3 of them, my friend had a hand in them.
I believe there are 2 or 3 people here who are taking their modifications seriously and have results. I cannot say who from the top of my head, but i expect great things from the one who is doing headwork and a rebore. Heavy duty mick also did a good job in my book, as far as simple mods were done, and he published his real results. Kudos to him too.
