Well I've fitted the carb but its far from happy.
When I blip the throttle its kinda running on like there is air leak
I did find that the pilot air jet did not have an hole through it?! - I've took it out completely at the moment. It made a difference but its not cured it.
I have a lot of small drills but I need to find out the size of the hole or buy a jet if ---- I new the size jet I need.
What jet are you referring to (above) when you say "pilot air jet"?
The fuel/air Mixture Screw has no hole in it.
I can't understand how the Pilot Jet could not have holes in it??
You need to pull the Pilot Jet, get the number and order at the least one # higher & one # lower.
When you've dialed in the best # Pilot Jet, it should idle just about perfect with the fuel/air Mixture Screw turned out (CCW) right around 1 and a 1/2 turns.
The Fuel/Air Mixture Screw is only for idle. Almost everything else is done with the Pilot Jet, the Needle Height & the Main Jet.
If I've just told you stuff you already know, I'm sorry, but you've confused the hell out me with the "pilot air jet with no holes in it" comment.
PS: running on for longer than normal before dropping down to idle speed sounds like a hair lean on the Pilot Jet to me.
Do you hear the slide click closed when you off the throttle?
