2006 and 2005 heads are a direct swap with no changes.
After doing head work on as many iron barrel heads as we have, I have had to inform a lot of people about this subject.
The main differences are external oil pipes and banjo fittings. The kick start models have the oil pipe feed from next to the tappet chamber, and the e-start models have the feed down by the front oil pump.
You can convert between them by cutting the oil pipe below the "y" junction, and splicing on the necessary top half or bottom half, as the case may be. A short rubber hose of correct diameter, and some clamps will work nicely to splice them together. Oil pressure is low in those pipes. If you prefer to solder instead, that works too.
Early model banjos are a different size than later model banjos.
Everything else is the same, regarding the actual heads themselves.
