Author Topic: Electra X started, discussed and ridden after big end replacement.  (Read 873 times)
Bullet Whisperer
Just finished today, the timing gears and valve gear seem to be responsible for any remaining noises, but it is a big improvement.
 B.W.
 https://youtu.be/E2EEMHgTLRQ
AzCal Retred
  • Chennai Wrencher
  • a journey of a thousand li starts under one's feet
Nice bit of sleuthing!
On the Japanese bikes the metallurgy seems to focus on surface coatings over mild (i.e. cheap) steel. Once through these, the part is essentially "gone". Is it the same thing on these Electra cams/lifters, or is there real metal to be had there?
Did the driver appear to be a dodgy lifter from the start, not spinning properly and so eating away at the cam nose? Or would running the valves too tight possibly affect lubrication of this cam/lifter area by not allowing a proper oil film to form, maybe initiating a cavity on the lifter rubbing surface?
Leveling out the lifter with the Dremel and fine wheel should stabilize things, but the "fix" may ultimately be new cams & lifters. There's no substitute for cubic dollars, but every rebuild runs into a owner-imposed money limit. At least this can be done in the frame when the owner's (or next owner's) bank account recharges.
Thanks for taking us through your troubleshooting process. Always something new to learn! Regards - ACR -
A trifecta of Pre-Unit Bullets: a Red Deluxe 500, a Green Standard 500, and a Black ES 350.
Karl Fenn
Well l think it's the age old business rebuilding an engine can be a very expensive business.
heloego
  • USA '12 C5, '06 ElectraX
Nicely done bit of work! So far, so good on my AVL. Just finished a Spring checkup of everything, fresh oil and gas, and no problems. Fired right up! Nice to get out again after my foot healed enough to get my foot into a shoe.  :P
'12 C5 Classic
