Thanks! Good stuff. I was going to use file labels folded-over like tags, but the Brady labels sound like a better idea. As I tracked-down and temporarily fixed my electric starting issues, I did a dissection of the wiring in the casquette I discovered that almost every wiring trunk had been deformed/flattened in places along the wrapping/sheath. I peeled-back the sheaths, and almost every wire within had several spots where the wire was bare and the insulation had been worn away. These spots lined-up with areas where the trunks had been randomly stuffed-in together and wrapped around each other. Friction and wear was inevitable given the close confines and the motion of the casquette during operation of the bike. Also inside the trunk sheathing the individual wire insulation was often flattened and wrinkled as if it had been ironed. All the wiring had been stuffed into the casquette without regard for any consequences from the turning of the front wheel or vibrations, etc. from riding. I could not find a cause for the melting/erosion of insulation other than their tight contact with one another. I think the bare wires shorted-out intermittently inside the sheathing. None of the components (solenoid, starter, headlight, signals, horn, etc.) showed signs of malfunction that would have cooked the wires, and the battery output voltage and load readings were all within normal limits. Nothing appears to have caused the damage except poor wiring technique and shoddy workmanship. It is chafed, worn, cooked and deformed in so many places that I think the best option is total replacement. I can locate no similar issues anywhere else along the wiring harness or on/in any connectors, relays, or fuses. Thanks again!
