As hoped, I took "Project MLG" out on a similar ~3.5 hour ride as yesterday's jaunt on the Interceptor. I started 30 minutes earlier, and I only took a 10-minute break to stretch my legs just shy of the 2 hour mark. Ambient temps started similarly, but ended up at 70°F (as opposed to 76°F) due to finishing an hour earlier.
First ~2 HoursDNA air filter, DNA filter cover, aftermarket metal side cover (
with CAI, no booster plug)
Ambient conditions at start of run: 57°F @ 92% humidity
Ambient conditions at end of run: 64°F @ 68% humidity
Avearage Ambient Temp: 61°F
Departure time: 07:29 AM CST
Elapsed time: 1:52
Distance covered: 90.7 miles
Top Speed: 74.6MPH
Avg Speed: 49.0MPH
Peak IAT: 86°F
Low IAT: 75.2°F
Average IAT: 78.3°F
Peak EOT: 210.2°F
Average EOT: 203.2°F
Avg Amb:IAT Δ : +17.8°F
Best Amb:IAT Δ : +11.2°F (ahieved 75.2°F during a high speed run near the first break with ambient temps ~64°F)
Worst Amb:IAT Δ : +24°F (near the end of the run driving through a resort area with a 25MPH speed limit)
Last ~1.5 hoursDNA air filter, DNA filter cover, aftermarket metal side cover (
Ambient conditions at start of run: 64°F @ 68% humidity
Ambient conditions at end of run: 70°F @ 50% humidity
Avearage Ambient Temp: 67°F
Departure time: 9:30 AM CST
Elapsed time: 1:04
Distance covered: 44.7 miles
Top Speed: 83.9MPH
Avg Speed: 44.2MPH
Peak IAT: 89.6°F
Low IAT: 82.4°F (15 minutes into run at speeds between 59-71MPH)
Average IAT: 86.3°F
Peak EOT: 221.0°F
Average EOT: 212.6°F
Avg Amb:IAT Δ : +19.3°F
Best Amb:IAT Δ : +16.0°F (achieved during the last 60+MPH run 10 minutes before end of data capture)
Worst Amb:IAT Δ : +23.8°F (right at the beginning of the run while departing resort area at low speeds)
Fuel consumed: 2.318 gallons
Miles between fill-ups: 137.5
Fuel economy: 59.32 MPG
The IAT:Ambient delta today did not quite ahieve the wider delta results from last week, although the overall temps were better (IAT and EOT). I attribute this to the front of the airbox getting heat soaked from radiated heat off the back of the motor, and inducting that heat into the plenum where the IAT sensor sits; during higher ambient temps, the heat soak effect is more pronounced (resulting in +30°F deltas), so the delta differential is easier to achieve and to measure during those high speed runs (above 50+MPH).
While the deltas were not as pronounced between this weekends' runs as it was during last weeks' runs, there is still a notable correlation of using the CAI to the following measurable data:
1. lower average IATs
2. lower peak IAT
3. lower average delta of IAT:Ambient
4. lower best delta of IAT:Ambient
5. lower peak EOT
6. lower average EOT
7. lowest delta of IAT:Ambient during the highest speed runs (whereas without CAI, this is where peak IAT tends to occur)
