Author Topic: Universal Vs Flexible adapter for AVL head bolts  (Read 622 times)
allanfox
on: July 08, 2021, 12:45:57 pm
Morning all
Just about to buy a 3/8" socket extension to help with retorquing head bolts on a 500AVL engine and a question if i may?
I am making the assumption you can retorque (5, 50, 500 miles etc) the head bolts without removing the rocker shafts every time if you use a universal joint adapter or flexible adapter, if so what are you guys using, Universal Vs Flexible socket adapter?
Or do I have to always remove the rockershafts?
heloego
  • USA '12 C5, '06 ElectraX
Reply #1 on: July 09, 2021, 06:23:13 pm
It should not be necessary to remove the rocker shafts, and a straight 1/4 inch extension will work fine.
'12 C5 Classic
