Author Topic: Suspected ECU  (Read 1794 times)
Charl SA
on: March 27, 2021, 10:22:18 am
Hi fellows.
So my 2014 Classic 500 is breakdown for 2 months now.
Symptoms :
MIL does not come on. Started at first and idled but when I turn the throttle the engine stalls. Now it does not even want to idle anymore.
Checks done:
Fuel pressure and filter, injector spray pattern and reaction. TPS setting and siring to ECU. Valves and fiming. Map sensor wiring checked. Rollover sensor checked. ECU VCC and sensorground checked. Throttle body checked and cleaned. Airfilter and fuelfilter checked. Battery connection checked. (Thick and thin negative)
Findings:
When I connect the single pole connector at the ECU to earth and I switch the ignition on (even though MIL does not come on when trying to start) it gives me fault codes for the following:
TPS sensor
MAP sensor
Roll over sensor
Injector circuit
Crankshaft position circuit.
 :o :o :o
What do you think.... Maybe faulty ECU?
Karl Fenn
Reply #1 on: March 27, 2021, 01:49:54 pm
Sounds like a main dealer sort out, In saying that the ECU is normally reliable, l have never had one go down.
viczena
Reply #2 on: March 27, 2021, 03:07:00 pm
Sidestand relay
www.enfieldtech.de
Harley CVO EGlide, Boss Hoss 502, BMW 1200 RT, Harley Panhead , Harley Davidson &Marlboro Man Bike BD2, Royal Enfield Trials, KTM EXC 500. And some more.
Karl Fenn
Reply #3 on: March 27, 2021, 04:06:57 pm
Could it be would it cause so many issues.
viczena
Reply #4 on: March 27, 2021, 07:27:02 pm
Yep, had the same problems after I changed my relays against the "better" ones.
www.enfieldtech.de
Freddy1
Reply #5 on: March 28, 2021, 07:27:35 am
AND A NEW SPARK PLUG?
ALSO RESET THE OLD LOG ERROR IN THE ECU.
AzCal Retred
  • Chennai Wrencher
Reply #6 on: March 28, 2021, 08:32:13 am
Charl SA
Reply #7 on: March 29, 2021, 04:36:24 am
How do you clear the old logged faults?
Freddy1
Reply #8 on: March 30, 2021, 04:55:34 am
This is the procedure to delete the codes of errors recorded in the ECU memory of Bullet EFI.
1- motorcycle off
2-connect to ground the special the purple wire coming from the ECU (otherwise the procedure does not work ).
3- open up completely the throttle
4- turn the ignition key to ON (but do not start the engine).
5- wait 10-12 seconds (if you wait more than 12 second the procedure does not work) and release the throttle grip.
6- The MIL light after further 5 seconds blinks rapidly 2 times and the memory is erased.
Tested procedure successfully on my EFI Bullet G5 2010.
Sorry if message is not understandable, translated from Italian by google translator.
Dinasaur
  • Fitter machinest RE Harley Ducati
Reply #9 on: June 25, 2021, 01:30:36 pm
I have a 2015 model 535 and many problems with mine but I have resolved them all now after much work first to change was the rear shocks the engine had all the usual issues so I converted it to carburetor with much better stability now the ecu played up so it got the chop too I bought a bullet rotor and a Chinese gy6 dc CDI module and eliminated all 3 interlock relays and the bike is now reliable and great to ride I also got rid of the fuse box for online fuses and deleted that pesky air box much better access to the harness I know people will disagree with the changes I did but believe me it's  better than when it was from new cheers
« Last Edit: June 25, 2021, 01:36:51 pm by Dinasaur »
GT 535 Harley Ducati
viczena
Reply #10 on: June 25, 2021, 03:11:40 pm
Yeah, you built in a crappy carb, a more crappy chinese CDI and an old bullet rotor, and now your bike is much more stable. What does it tell me about the quality of the 535?
« Last Edit: June 25, 2021, 03:26:07 pm by viczena »
www.enfieldtech.de
Dinasaur
Reply #11 on: June 26, 2021, 04:09:14 am
I used a Harley cv 40mm carby the rotor is new from late model the CDI gives a much better spark and you are quite right the whole fuel injection system and wiring does have issues the overall quality is good you must have seen many posts here from people with problems with the gt 535 but once they are addressed the bike is good on a side note I have built many custom Harleys cheers
« Last Edit: June 26, 2021, 04:12:22 am by Dinasaur »
viczena
Reply #12 on: June 26, 2021, 06:36:03 am
That does not make your bike a Harley.
www.enfieldtech.de
AzCal Retred
  • Chennai Wrencher
Reply #13 on: June 27, 2021, 03:00:43 am
Dinasaur - well done. You tamed a troublesome beast & simplified it as well. Better to be riding than scratching your head second guessing a trouble code. Some folks here wouldn't be happy even if they were hung with a new rope, but the rest of us admire your efforts and innovation.
Nitrowing
Reply #14 on: June 27, 2021, 03:22:26 am
I'm sure he's thankful!  ;D
No wonder we no longer have a motor industry
