The top compression ring will either have a silver top side, or it will have a small chamfer or shoulder on the inside circumference which will go on the top side. If there is no chamfer or shoulder, and the edge is barrel-faced or flat, then it can go either side up.
The second compression ring with the tapered edge will go with the wider part of the tapered edge on the bottom side. So that it "scrapes" the oil down the bore, because half of the job of the second ring is oil control.
The oil control ring can go either side up. They are not directional.
