OK, I'll bite. Given that spigot, how do you lap in the cylinder head joint? I've cleaned up gasket surfaces in the past, using a sheet of plate glass and a rotary motion - can be done on fine wet or dry paper, or I suppose with fine grinding past. But for this joint, what procedure do you recommend?
