That sounds like a good suggestion to turn the fuel off and drain the float bowl.
The procedure I've adopted for cold starts is, choke ON, ignition OFF, throttle shut, 2 or three kicks to prime the engine, then choke OFF, ignition ON, throttle just a bit open, usually starts on the first kick thereafter. And as OP says, usually starts first kick for the rest of the day.
