I finally got my velocity stack installed but will have to wait until the morning to see if I can notice any difference. A couple of days ago I received my new compression tester and discovered that after several attempts all the readings were 60PSI; not good. The quickest solution for me was to buy a standard barrel and piston set from our host, that way I'll have a spare barrel on hand if I ever need to do a +10 thou rebore and get the matching piston that is in the 'online store'.
I have the crankcase gaskets, head and base gaskets, kickstart seals, new oil pump plastic drive cog, new primary (Renold) and drive chains, front and rear sprockets, cush drive rubbers as well as the rocker cover seals and O-rings. I hope I haven't forgotten anything.
To change over the primary chain, does releasing the tensioner provide enough wiggle room to slide the chain off or will I have to remove either the crankshaft sprocket or clutch basket to do this?
My Haynes manual mentions a special tool required to remove and install the head nuts. Is it required, or will my 3/8" or 1/4" drive sockets set fit the bill?
I like to be prepared before I start to operate so that I on't have any surprises that will mean the bike's guts will be subjected to humidity changes in the carport when it lives.
