Author Topic: Amal carb in bullet electra x  (Read 909 times)
del7863@hotmail.co.uk
on: May 30, 2023, 11:52:06 am
Seems like a daft question, I have recently bought a bullet electra x with Amal carb upgrade, I’m not sure when the choke is on or off
Adrian II
Reply #1 on: May 30, 2023, 12:59:01 pm
The choke is on when the choke plunger in the throttle slide is in the down position, off when it is raised.
Paul W
Reply #2 on: May 31, 2023, 10:50:17 am
The cable pulls the choke off. The choke slide is spring loaded to on, so if the cable breaks the choke goes on.
Seems illogical but that’s the way it is.
Paul W.
allanfox
Reply #3 on: May 31, 2023, 01:08:52 pm
You might find that you don't even need the choke as the tickler makes sure it starts and the AMAL  pilot circuit is quite rich anyway, never use mine, it is still fitted but I have tightened the lever right down so any vibration doesn't put the choke without me noticing. I will be removing it at some point.
Paul W
Reply #4 on: May 31, 2023, 06:46:42 pm
I agree, I removed the choke from my concentric (Wassell copy) after a very short while after buying the cable and a handlebar control because I’ve never needed to use it.
Paul W.
