Author Topic: Oil top up  (Read 772 times)
nettshubby
on: July 08, 2024, 03:56:52 pm
Is there a correct time to check and top up the engine oil on my 500 Bullet?
I found last week there was no oil showing on the dip stick, with engine cold in garage, so topped it up.
This week after a couple of runs I again checked it and it was only just on end of dipstick!
There are no leaks, no honestly! And no smoking exhaust.
I seem to remember there is a sequence to follow when checking the level. The manual doesn’t give any info apart from amount and grade.
I WILL get this thing going! 🤯
AzCal Retred
  • Chennai Wrencher
Reply #1 on: July 08, 2024, 05:02:41 pm
The pre-unit has a dry sump engine and a seperate oil tank. Best to check after it has run a couple minutes and everything has had a chance to find a proper level.
allanfox
Reply #2 on: July 08, 2024, 05:54:52 pm
Run it for a 4-5 minutes and then let it rest for 2 minutes before reading the dip stick, oil should be circulated and any splash run down giving the true level, topping up from cold will usually mean oil coming out of the breather as you will have overfilled it. Unless of course it really is low!
nettshubby
Reply #3 on: July 08, 2024, 06:22:11 pm
That sounds about what I half remembered from past ownership.
Thanks for replies.
nettshubby
Reply #4 on: July 08, 2024, 06:26:35 pm
On another note, when posting a message, how do I set it to receive an email notification of replies? Is it the little email icon in the top column?
stinkwheel
Reply #5 on: July 08, 2024, 07:06:58 pm
As above. Also don't worry about it being on the tip of the dipstick, that's not dangerously low. Dangerously low is a fair bit below dipstick level. Here's a picture of the oil tank area of a bullet with the cases split and the dipstick in place. As you can see, if it's on the tip of the dipstick, the oil tank is still well over half full.
Some of them seem to prefer running at the bottom of the dipstick and persistantly puke out oil that is topped up higher. I do wonder if they genuinely need a longer dipstick sometimes.
nettshubby
Reply #6 on: July 08, 2024, 08:07:51 pm
My bike has the double tubes on an extended filler, with a longer dipstick.
I should think the overall length will be the same. I’ll get the torch and ruler out to check.
Comforting info though! It did run fine with “no” oil showing!
Raymond
Reply #7 on: July 08, 2024, 09:51:19 pm
SW's well-illustrated point on low oil level according to the dipstick but bike runs fine is very reassuring. Especially in a week when my newly-rebuilt Bullet had some sort of seizure and I'm trying to eliminate reasons for that - low oil very unlikely to be the cause.
In the garage:
2007 Kawasaki W800 SE Polly
1978 Yamaha XS650 Miss November
2003 Royal Enfield Bullet 500 Deluxe
  • There are no truths outside the Gates of Eden
Reply #8 on: July 09, 2024, 01:07:27 am
       Click on Notify.
allanfox
Reply #9 on: July 09, 2024, 10:51:06 am
I have the same set up and it is the same level across both dipsticks, I would be cautious about 'no oil' showing as it may be well below!  Just run and check and keep topping up and playing about until you find your happy place and are confident about the level, it is less of a science and more of a dark art!!
I personally never go about half way up the dipstick or it will fill the catch can.
AndyMcP
Reply #10 on: July 10, 2024, 07:46:41 am
When you park the bike, try and leave the piston near TDC.  This helps to prevent the oil draining into the sump (Wet-Sumping) through the oil feed pump over time.
« Last Edit: July 10, 2024, 07:55:35 am by AndyMcP »
michiel
  • Bullet 500 1992/Meteor 2021, Germany, Hamburg
Reply #11 on: July 10, 2024, 07:48:52 am
The oil level is measured AFTER the journey. After approx. 5 minutes.
ddavidv
  • Prefers "Your Majesty"
Reply #12 on: July 10, 2024, 12:39:23 pm
The 'stopping past TDC' is a good practice. Also sets the engine up for kick start.  :)
Mine will 'reject' oil levels past about the halfway mark. Turns the engine into a Scottoiler as my breather has a duckbill that moistens the chain.
2023 Scram 411, 2007 five speed 'Deluxe', 1964 750 Interceptor
stinkwheel
Reply #13 on: July 10, 2024, 01:13:33 pm
I find killing the engine with the decompressor almost invariably means it comes to rest just before or after TDC.
