You need a ‘C’ spanner. Measure the diameter of the ring then search online.
Hi allHow do you turn the nut with the 5 position tension notches? I want to make it as firm as possible but no idea how to turn the nut at the bottom of the spring. The bike didn't come with a tool for it.CheersJustin
So I bought a C spanner but it didn't work. So I just gave it a good heave with a pipe-wrench. I did lift the back wheel off the floor a little but I think the nut would have moved with just the pipe-wrench.
