Hi all. Haywards don't deliver. They gave me number of a van courier. Quoted me £150. Seems reasonable. Adrian ll is that a magneto? Marvellous set up if so.
Another question. Can you put gear oil in the gearbox or must it only be grease. If so how do you check the grease amount already in there without stripping the box?
That's a shame, the delivered my new Electra-X down to (Old) Hampshire in 2005. Maybe for new bikes only?
Yes that is a magneto, a refurbished BT-H BKH1TT racing mag which came up on eBay and no-one else wanted to bid for. A not too daunting bit of home engineering was need to get it to fit. That same seller has the non-racing version of the same magneto, fully refurbished, listed at the moment, no bids yet. eBay item 156263648673.
There is a magneto which will bolt straight on, the Lucas SR1, which was fitted to English-built 350 and 500 Bullets in the late 1950s.
I had a working one fitted when the engine was rebuilt, but sadly it quietly died while I was finishing the rest of the bike, which is why I also experimented with the old Pazon ignition I had lying around. I'll try a new condenser on the SR1 at some stage as it did spark pretty well. Plenty of these still around, though a good used auto-advance unit can be hard to find, new ones are available but pricey.
A.
