Ok, thinking heads on.
Firstly there is nothing wrong with Amals, yes there are better carbs but the vast majority of 60s and 70s bikes used the Amal concentric without issue, so let's park that one.
If you bike is bogging when you open the throttle (and you have said it runs fine with the Mikarb) it is one of two things (maybe three, maybe four) firstly too much fuel at one, secondly too little fuel and it is being delivered too slowly and thirdly a blocked air filter but we have covered that already. Lastly an air lock in your filler cap, but unlikely if the Mikarb works. How about a blocked fuel tap, remember the AMAL will be trying to draw more fuel than the Mikarb was and maybe it can't?
I think it is too lean.
So, when you open the throttle (soft snap) the needle raises and lets the fuel mixture through all at once and quickly if it isn't there really isn't much it can be other than a blocked/damaged needle valve seat or a sticky or leaky float, is the float pin bent, and does the float move freely up and down (I guess yes) If the float has a leak it will be too heavy to respond quick enough and will starve the engine, have you tried submerging it in a cup of petrol to check it isn't leaking?
Please keep us posted if it gets sorted or chucked out of the window!
https://www.jrcengineering.com/technical-support/amal-concentrics-tuning-and-jetting/
Will keep the post updated as I go along.
firstly its a brand new carb, bought about 3 maybe 4 months ago and with test runs up and down the lane I doubt its done a mile in total use as the lane is about 100 yards total length.
Float height has been confirmed and its a stay up float fitted from new, fuel shuts off and ticker works as it should so assumption that its not holed at present as no leaks.
Brand new air filter that came with the cab kit, if you put your hands over it at tick over you can strangle the bike till it cuts out, no air leaks on carb side tested with WD40.
petrol cap has been checked and you can blow though the breather hole both ways
Petrol Tap is one from Mr H and fuel flow seems good, always fuel in the pipe even when revving the bike up.
Head gasket replaced last weekend and re sealed with automotive rtv however inside of combustion chamber is very black per the photo, no sign of any oil use so assumption is currently that its burning rich. valves are dry just angle of light on the photo
