Hi, I have a 2021 Classic 500. and I want to add a sidecar.
Now, to reduce the trail , I am thinking about fitting offset axle front forks.
Would that reduce the trail enough for sidecar use, or should you do something more drastic ?
I guess the best would be to have a set of Earles forks made up.
Not sure I want to go that far.
Maybe leading links ?
Look for stiffer springs, or dampers ?
Any ideas out there ?
Thanks,
Hans
