Author Topic: Replacement front bleed nipple  (Read 595 times)
butchgoesbush
on: July 08, 2024, 10:36:34 am
G’day all,
I changed my brake pads and was in the process of bleeding my brakes when my front bleed nipple… stripped.
Much cursing and straining later, it’s still in place but swaddled in lubricant and I have high hopes for another go tomorrow.
I will however need to replace the bleed nipple, does any one know the size/ type required?
Cheers!
Dexter
  • British Columbia, Canada
Reply #1 on: July 08, 2024, 05:03:24 pm
Welcome to the forum Butch!
"Stripped" generally means the threads have been knackered, but your description seems to indicate the bleeder valve can not be removed? Maybe you have used the wrong sized wrench and turned the corners off the bleeder head?
I have tried to ascertain the size of that bleeder valve, to order Speedbleeders for the calipers, to no avail. I even asked the local RE dealer, when I bought my Meteor in 2021, but they were of no help. Maybe their parts book has improved since then.
Past rides:
1966 Honda 65 Sport
1967 Honda CB160
1973 Honda CB750
1982 Honda V45 Magna - the most uncomfortable bike I ever did a cross country tour on!
1983 Honda CB1000
1995 Honda ST1100 - sold 2015 after 175,000 km
1996 Honda ST1100
Current ride:
2021 Royal Enfield Stellar Blue Meteor 350
butchgoesbush
Reply #2 on: July 10, 2024, 03:01:38 am
Yep, the edges of the bolt have been rounded off - I used the same wench for the back bleed nipple, and tried a size down & a size up when initially started to round off the edges.
I have ordered a replacement - but with a 6-8 week wait time I definitely hoped I could find something that worked in the meantime
  • There are no truths outside the Gates of Eden
Reply #3 on: July 10, 2024, 11:50:39 am
     I've learned over many years of bleeders on cars & bikes to always use a box end wrench. I hope that's what you're using. Good luck with yours. Some can turn into a real nightmare.
     Have you gotten the bad one off yet? Could you get a small Vice-Grip on it?
« Last Edit: July 10, 2024, 11:52:44 am by tooseevee »
