@Adrian: Probably it's even the better way.
Finally I started work on the gear change mechanism!
I was thinking about several options, but none of them was really good or would have worked without having bad side effects. After all I found one that pleases me.
The main problem was the rear set foot rests and a resulting position of the gear change lever.
The lever just turned backwards would result in a very short lever, high forces and a switched shift pattern - not accepable!
One could just fit a lever and some sort of linkage. But still you'd have to find a good way of mountig it on the bike and you'd have a lot auf links and joints on the outside. Not an issue on a racing bike, but on a "dirt bike" that's crap.
So I chose a different approach.
Here's the basic layout of the Albion gearbox everybody knows and loves
Now here's my idea. As standard you'd have a "negative" ratio with the lever on the shaft beeing longer than the one on the ratchet, which leaves you with quite a long foot lever. So if you changed this ratio, you could mount a shorter lever. And the ratchet and lever go different ways. If you were to mount the lever backwards, you'd have to have both going the same direktion, to stay with your known gear shift pattern.
So I changed the levers to a linkage. To achieve that, I first shortened the parts and turned the rachet 90°:
The linkage looks adventurous, but there are quite some obstacles to look out for!
First tests were promissing. Next I have to make the top and bottom plate to cope with the turned assembly.
But this gives me some advantages:
-Same shifting force as usual
-Keeping the shift pattern
-Keeping the neutral finder
-No outside linkage
One problem is the spring that pulls back the lever. This way I can't use it as it was before and I have to figure out a different way of doing it, but I'm on that!
So long,
Andreas
