In this particular bike the timing is somewhat retarded particularly at slower revs. I don't have the equipment to get a perfect ignition map so it's mainly set as per experience and seat dyno. Below 1000 rpm the timing is set to be at/after TDC mainly for better kick starting performance and to avoid unpleasant kick backs, broken legs and busted free wheels on the drive shaft of the crank. Also when the battery is weak and doesn't turn over the engine as fast I've experienced kickbacks with the ignition timing set to the values as Hitchcock's do.
Anyway lubed the chain and rode shopping yesterday, hitting maybe 170kmh? I don't know my speedo doesn't go as far, and the last thing I'm going to put on this bike is a gps tracking device sending my coordinates to some "good" person at the police department via the mobile network.
