Awesome. What route are you taking?
The RouteAs much of the old highway from Kempsey to Port Macquarie, then boring highway to Taree. The Bucketts Way to Gloucester, then The Thunderbolts Way to Walcha. Ten bikes from the club (most of them took off at ridiculous speeds while 3 of us enjoyed the corners, the sights of the Spring lambs bouncing around in the paddocks, wallabies sitting up at the side of the road having a gawk at us and of course dodging the ever-present 'roo road kill.
At the motel at Walcha, there were 3 cars and at least 30 bikes ranging from one small GT535 to KTM RC8s with auxiliary fuel tanks, Harleys of every size and even a couple of the grouse Vulcan 650 goers.
Apparently there was a huge dirt bash going on nearby that weekend and guys had rocked up from Queensland.
On Sunday morning, three of us split from the group who were heading North up to Ebor, Dorrigo, Armidale. Instead we decided on what has to be one of the greatest motorcycling roads on the planet; The 300 corners of the Oxley Highway heading East from Walcha to Port Macquarie. Those 65 / 75 / 80km/h signs at the corners are only a guideline,
BUT the 25 / 35 / 45km/h signs can be the difference between life and death! Armco barriers 'protecting' you from a precipitous drop on one side and the other is a vertical rock face and surprise tightening-radius corners; what a blast!
Hey Gizzo, you'd have to rotate your muffler clamp around further
I covered just over 620km and found that kick starting is less embarrassing than the starter motor churning over repeatedly.
The YSS fork upgrade resultsI didn't have time to test the fork improvement before I left on Saturday morning, but as soon as I traversed my driveway apron down to the cambered road, I knew the forks had undergone a change that was transformational. I'd delved into the progressive vs linear fork spring debate and discovered these comments on a forum which made me thankfully choose the linear springs which I find so compliant. The front end now floats over obstacles (particularly those tarmac patches which sit proud from the surface of the road - we know the ones!).
Thanks again to Streetkleaver for the feedback on his linear springs and also for the Loctite 567 idea for the damper rod screw.
Linear vs progressive fork springsProgressive springs give you a plush feel for the first part of fork travel, but have a stiff secondary winding, so once you blow through the first part of travel you have a very harsh feel as the fork compresses.
A linear winding will be stiffer initially but will have a softer spring rate than the secondary rate on a progressive spring. Overall, the linear will give a better performance on rough roads.
Progressive springs are a big advantage to resellers, as it allows them to have lower overheads (fewer items). However, progressives tend to be a jack of all, master of none solution. As mentioned above, too plush then too hard.
If you are spending the money on your ride, then I would always go with a proper linear spring rate setup for you. The problem with progressive springs is that you cannot valve the forks to suit the spring, as its rate is constantly changing. So if re-valving, then it is best to go for linear springs to suit your weight/style.
