The multicurve TCI unit varies the ignition timing based on engine rpm and throttle position. It also retards the ignition timing when cranking / kicking the engine over to prevent kickbacks, which can damage the sprag clutch. If you wanted to use a different carburetor without the TPS, an option is to maybe try out the green TCI unit from the Electra X. Another aftermarket option for the TCI unit used on the Electra X was the GS125 Suzuki TCI, I have not personally used the GS125 Suzuki TCI, but maybe Adrian might be able to provide some insight.
