Author Topic: Returning To Motorcycling And Thinking of Royal Enfield  (Read 6524 times)
Reply #15 on: November 11, 2012, 01:01:21 am
I guess you guys now know what's on my Christmas list...
Reply #16 on: November 11, 2012, 06:18:51 am
Yes, I think it's a 45 or 46MM.
You have a good memory - the large nut for front sprocket is 46 mm.  Even a slightly larger socket 48 mm (1&7/8") can be used to unscrew the nut.
« Last Edit: November 11, 2012, 07:07:23 am by singhg5 »
Shavuotis
Reply #17 on: November 12, 2012, 03:49:20 am
Once again, thanks for the input guys.  Are there any things I need to add to a new RE to increase the reliability and performance of the new UCE RE's?  Wonderful bunch of guys here.   :)
Reply #18 on: November 12, 2012, 05:18:09 am
Some of the wiring harness may be exposed to sharp metal edges so it pays to protect it.
This is especially true in the side box which contains a lot of the relays and fuses.
In several places I found that short lengths of rubber or vinyl tubing could be slit from end to end and slipped over the wires to protect them. (See photo below)
Also make sure the wires that are running back to the tail light assembly are snugly hooked into the tabs that keep them off of the rear wheel.
If you use the search feature you should be able to find other posts that will tell you how to get your headlight switch to work (DOE mandated that it should be always on), the best spark plug to replace the crummy Bosch that comes with the bike and dozens of other improvements we commonly make.
