"Yes" for what works for me:
(1) Wipe clean the cover and gasket in hand. (2) Wipe head and saddle free of any oil and sealant. Place gasket loose on head, this done to allow a relatively care-free handling of the cover with hands. (3) Bring in the cover. (Its a light compression captured gasket, so some tacky grease use is totally acceptable for a non-pressured install.) Lift up gasket into grove, and where it doesn't stay up a light grease wipe is ok. The cleaner oil-free you've gotten the parts the less grease you need. Keep the saddle plug clear of grease. (4) With the cover now mostly in position and lowered on the right, but being held up on the left (a bit above the plug saddle) , lightly swipe the saddle with your favorite RTV. I prefer an oil-use black. Use whatever floats your boat, really. So little is needed that you can't even see any oooze later. Lower the left , eyeball the entire perimeter, then if good, tighten up properly.
(5) Route that forward breather hose and install it, position tank onto front mounts, ;lower rear of tank enough to install that vent hose, lower and install rear bolts. Install horns. Viola.
Remember : You've only removed two vent hoses and the horns, so there's not much to re-attach.
