A friend of mine got me involved in working on an off grid, standalone system in Kentucky. He's been trying to convince me that panels can be had for 50 cents / watt, with quite substantial output. From what I've seen, we aren't quite there yet, but close.
I think I'd spend a bit more than the little Harbor Freight panels, 1.5 watts at 24 volts is only 60 mA, and in practice, I think one would be lucky to see 2/3 of the rated output. By my calculations, it would take a month of sunny days to bring a 12 A-hr motorcycle battery from 1/2 charge to full with one of these.
I think I'd start with something larger. Maybe this 20watt kit:
https://www.amazon.com/Battery-Charger-Monocrystalline-Controller-Extension/dp/B091CYD2DH?th=1 Still pretty affordable at three times the price, but has 4.5 times the surface area of the little Harbor Freight gadget, and includes a controller.
What I'd really do, however, is put my money into a 10 or 12 gauge RV extension cord from my back porch. That solution gives me lights, sound, and power tools, as well battery charging. And this is what I did when my garage's underground power feed failed. I would gotten away with it too, if I hadn't hung it from the clothesline to keep it from underfoot and under lawnmower. As I found out from the document the building inspector left in my mailbox, there are a lot more rules for "overhead power lines" than there are for extension cords. Luckily, an easy fix, lying on the ground, and with the disconnection junction clearly visible so as to establish it's "temporary" nature, my 50 foot extension cord was entirely acceptable.
