To start, I was putting the head on the new barrel today and when I got to reinstalling the de-compressor it dawned on me the last person to work on the bike probably didn't put it back together right. It has one steel flat washer, one large flat copper washer at the top of the unit and that's it. When I looked at the washers in my de-coke washer set I had a large round copper washer and a small round copper washer which seems to make sense for sealing the lower portion of the unit. A closer look at the head showed a small port in the space between the top and bottom of the cavity which I am assuming vents to the exhaust port. There was a discussion the other day about these washers but I wasn't quite grasping the whole thing. So do I now understand that small round copper washer goes on the bottom, then the large round one at the top backed by the flat steel washer. If that's the case then what effect did only having a flat steel washer at the top with a flat copper washer and no washer at the bottom have ? I must have been losing some compression with that set up.
The other question also has to do with copper washers. The banjos for the oil feed to the rockers had no sealing washers when I removed them at the start of this project, I put this down to the last guy working on the motor didn't put them back, oil was seeping at those points. I expected to have four new copper washers in the de- coke kit but there were none making me question whether or not they were used at those joints. I did have some copper washers in my parts bin that fit so I sealed the joints with them. The question is did these joints originally have washers or not? seems like they should have.
