Author Topic: spark plug cap  (Read 1475 times)
sjbiat
on: December 07, 2021, 02:02:23 pm
I always struggle to get the spark plug cap to snap into place.  I finally discovered its a lot easier if I remove the spring ring.  Do other people do that?
Stephan
stephan
09 C5 with Cozy sidecar now
formerly
97 Motoguzzi
94/02 Ural
85 BMW R80
64 BMW R60/Hollandia/Steib
61 BMW R69/Watsonian
60 Pugeot
Haggis
Reply #1 on: December 07, 2021, 03:13:57 pm
I changed the rubbish metal covered cap for NGK.
Off route, recalculate?
sjbiat
Reply #2 on: December 07, 2021, 04:19:22 pm
do you know the part number?
stephan
formerly
97 Motoguzzi
94/02 Ural
85 BMW R80
60 Pugeot
Guaire
Reply #4 on: December 08, 2021, 06:36:31 pm
If your plug has resistance, you don't need more resistance.
https://www.youtube.com/watch?v=U9fVUEaiB6I&t=35s
Haggis
Reply #5 on: December 08, 2021, 09:23:09 pm
They come from the factory with a resistor cap and a resistor plug.
Only magneto ignition requires reduced resistance.
Definitely change the oem ht lead though, it's cheap and nasty.
Nice bit of copper core silicone lead will last longer than the bike.
« Last Edit: December 08, 2021, 09:33:18 pm by Haggis »
Guaire
Reply #6 on: December 08, 2021, 10:12:48 pm
I like replacing the stock spark plug cap. It always looks ready to ground out.
  The video shows a further modified ignition, with a DynaTek coil, iridium plug... and the copper ignition wire. This set up does better than the stock.
  The photo shows the Dyna next to the stock coil.
dickim
Reply #7 on: December 09, 2021, 05:20:43 am
Maybe don't wait for it to fail- like mine! wouldn't start so pulled plug cap off which fell into pieces 😣 salvaged one from a dead fire pump and ordered new NGK as the guy's suggested (had allready changed to NGK Plug)
2020 RE 650 GT (Mr Clean)
2014 C5
56 MGA
58 Healey 3000 (Resto in Progress)
2001 MX5
2015 Mitsubishi Ute
2021 Camry Hybrid
Tipo 184 Kit ordered & awaiting delivery for build👍
Carl Fenn
Reply #8 on: December 23, 2021, 08:53:23 pm
I got rid of that crap cap and replaced it with NGK l had sparking issues the HT lead kept coming lose changed the cap and lead the bike has been fine since also fitted an iridium plug which is a great help does close to 100 a gallon.
stefano_musica
Reply #9 on: December 31, 2021, 01:35:20 am
2010 Classic 500. Still on the original cap, lead, coil and have only changed the spark plug, always used an NGK BPR6ES. Never had a single issue in 60,000km. Consistently get 300km from a tank of fuel. I’m 112kg and the panniers are always full. Tool kits, tyre irons, tubes, gear.
2010 Classic 500 - 45,000km and keeps on thumping
2013 Harley XL1200C
dickim
Reply #10 on: December 31, 2021, 07:48:25 am
YUP- way to go, mine literally fell into pieces
2014 C5
56 MGA
2001 MX5
2015 Mitsubishi Ute
2021 Camry Hybrid
Carl Fenn
Reply #11 on: December 31, 2021, 02:17:34 pm
I went for quality NGK.
