Author Topic: Torque Spec Master Sheet  (Read 38346 times)
BlackIce619
  • California
on: May 21, 2021, 09:12:22 pm
All,
 Attached is the Torque Spec Master Sheet that I decided to put together. It took a couple of hours to go through the entire service manual. Using the service manual available on this forum, I highly recommend you download the service manual and "Index" it in order to help search results come up 10000% times faster (immediately).
The document is put together in the order the service manual calls out the torque value items. Option to filter in excel allows the ability for you to search keywords or any other details in each column.
I have added a column for lb/ft, which is converted and rounded to the whole number. You can see the formula in the cell.
In order to check for errors, I have included the following column names: Name, Torque Spec (N-m), Torque Spec (lb/ft), Allen/Socket, Size, Notes. If items required specific tools or notes in which I have found stated in the manual I wrote down. There is only 1 line item that has a funny... "HEGO (02) Sensor" torque was weird to find in the manual.
I hope this tool saves you all time to quickly find torque specifications needed. As you find errors or name corrections, please let me know and I will try to update.
LINK TO FILE: https://drive.google.com/file/d/1algrSMXodhGoAeMFa8dvORuwZVMEi7od/view?usp=sharing
UPDATE: How to index the Service Manual to be able to search instant: (YouTube Video)
https://www.youtube.com/watch?v=2--GOApMZ5A
« Last Edit: May 29, 2021, 07:29:44 am by Dantheman »
2019 RE Continental GT 650 - Ice Queen
drums4money
Reply #1 on: May 21, 2021, 09:45:03 pm
All,
That's about spot-on with what I put together.  Went page by page through the manual, also.  Nice job!
If anyone hasn't already downloaded the full service manual - do it!
Takes a minute or two, but you'll find it's invaluable.
Drums!
hypocrite, four flusher, snake in the grass, just a swindler and wolf in sheep's clothing. . . . liar.
Hog Head
Reply #2 on: May 22, 2021, 05:12:25 am
Great stuff!!!
If I could suggest:
Group in headings - engine, chassis, wheels etc....
A column for In/lbs would be nice for the values say under 20 ft/lbs.
« Last Edit: May 22, 2021, 05:34:58 am by Hog Head »
Ducati Supersport S
Harley XR1200
Triumph T-120 Bonnie (Hinkley)
RE 650 Interceptor
Harley XL1200R
greentrumpet
  • UK, 2019 Interceptor
Reply #3 on: May 22, 2021, 02:10:44 pm
Thank you that's brilliant sharing the benefits of your labour, much obliged.
BlackIce619
  • California
Reply #4 on: May 22, 2021, 10:14:16 pm
Great stuff!!!
If I could suggest:
I will add the In/lb and update link. Should be. Quick fix. The headings would be more of a preference for some as I just quick filter search by name or sort alphabetical and do a quick find as well.
BlackIce619
  • California
Reply #5 on: May 23, 2021, 12:18:47 am
Link UPDATED - Included in/lbs for all torque values as reference.
Tentative update: Considering taking the time to add a Page number where the Torque value is provided in the service manual. (Idea provided to me as an example from "drums4money")
Intybe
Reply #6 on: May 25, 2021, 03:10:07 am
+1
BlackIce619
  • California
Reply #7 on: May 25, 2021, 08:33:50 pm
Link UPDATED - Page number number reference has been added. All torque specs under 20 ft/lb have been highlighted GREEN in the in/lb section.
Please make sure to review and let me know if you find any errors or areas that may need adjustments. I will keep it as updated as I can for you all.
zimmemr
Reply #8 on: May 25, 2021, 08:38:30 pm
You're a dedicated guy, my hat's off to you.
BlackIce619
  • California
Reply #9 on: May 25, 2021, 08:42:07 pm
I have to give credit to drums4money. He provided me his example of a similar sheet. I used his sheet to combine into mine, then added the ones in which I could not match manually. Either way, I will lean on the group's support to catch any errors or details that need to be updated.
Either way, let me know if you want to see any further updates on the document.
« Last Edit: May 25, 2021, 08:44:20 pm by BlackIce619 »
tinkergramp
Reply #10 on: May 25, 2021, 08:47:42 pm
Thanks to BlackIce619 and drums4money for sharing the results of their efforts with us!
Like zimmemr, I tip on my cap to you.
Honda CB 200
Yamaha XT 250
Yamaha XT 500
BMW R100/7
Royal Enfield Interceptor 650
Blazes Boylan
  • Brooklyn
Reply #11 on: May 25, 2021, 09:03:05 pm
Thank you guys indeed!
Semanticks
  • 2019 Interceptor Ravishing Red
Reply #12 on: May 27, 2021, 02:24:27 am
Maybe Bilgemaster can pin this??? :)
South Okanagan BC
Bilgemaster
  • Just some guy
  • Global Moderator
Reply #13 on: May 27, 2021, 02:40:44 am
Way ahead of you, Semanticks. I've already punted it to the Admins for consideration.
And well done, BlackIce169!
BlackIce619
  • California
Reply #14 on: May 27, 2021, 05:53:16 pm
I am unable to modify the original post, so I wanted to show you all how to index the PDF Service Manual to search instantly. Below I have found a link that walks you through the process and also shows you an example of Index vs. Non-Index.
If an admin can copy and paste this information or link to the original post, that would make it easier for those who read it for the first time  8)
