Author Topic: Brake shoes  (Read 649 times)
scouse
on: February 07, 2024, 03:31:20 pm
Can anyone tell me the best brake shoes to get my brake performance is bad. The brakes I have now are not the original but were bought from a reputable dealer in the states.
stinkwheel
Reply #1 on: February 07, 2024, 04:30:44 pm
I just had a set relined by a motor factors. Not for an enfield but they were on another bike which had truly apalling brakes.
I was a bit put off by the price but having ridden the bike, I'm going to get my bullets ones done too with the same stuff.
For reference they used TRIMAC MR2215 on mine. I think that's a UK company but I'm sure there is a US equivalent. Ferrodo always used to be the goto relining material.
The motor factors I used usually deals with heavy goods vehicles but they said they can get pretty much anything relined. I did have to shape them a little with some course zinc oxide paper and put a chamfer on the leading edge but they were pretty close to concentric out of the box, just a little over-thick, I didn't need to mess about with chalk lines and suchlike.
EDIT:  I should add, there is a lot you can do with setup on bullet brakes, a small tweak can be the difference between adequate and apalling brakes. Particularly getting the shoes centred and paralell with the drum. I tend to do the final tightening of either the hub centre nut on the front or the wheel spindle and anti-torque bolt on the rear with the wheel in place and the brake held on so everything is centred before being locked-down.
« Last Edit: February 07, 2024, 04:34:09 pm by stinkwheel »
AzCal Retred
  • Chennai Wrencher
  • a journey of a thousand li starts under one's feet
Reply #2 on: February 07, 2024, 05:01:23 pm
There is a lot of info here on the Forum about setting up and adjusting the front brake. The Hitchcock's "sticky" shoes work very well, a real improvement over O&M "lifetime" shoes. Bullet Whisperer races with a ventilated drum "1950's Hot Rod style" and has had good results. Search on "brakes".
A trifecta of Pre-Unit Bullets: a Red Deluxe 500, a Green Standard 500, and a Black ES 350.
Raymond
Reply #3 on: February 07, 2024, 05:32:40 pm
I'll just echo that point. Front brake on my Bullet's was awful - somebody had modified the brake by drilling out the trunnion on the tls link rod. With that replaced, brake dismantled and cleaned, pivots lubed, re-assembled with the brake arms parallel, the brake has been transformed to perfectly acceptable.
In the garage:
2007 Kawasaki W800 SE Polly
1978 Yamaha XS650 Miss November
2003 Royal Enfield Bullet 500 Deluxe
Adrian II
Reply #4 on: February 07, 2024, 11:06:21 pm
The drilled trunnion was a Hitchcocks' mod - it has come in for a fair bit of criticism.
A.
allanfox
Reply #5 on: February 08, 2024, 09:23:40 am
If you can speak to these guys, great old school service and quality product, transformed mine.
https://villiersservices.co.uk/product/brake-shoe-re-lining-service/
Paul W
  • 350 Bullet Electra (Indian home market).
Reply #6 on: February 08, 2024, 03:31:13 pm
I’m pleased to know that someone else has found the improvement the new linings provide. They’ve also done the rear shoes on my little car (the photo in the advert might even be the ones they did for me) and they’ve worked really well on that, too.
Paul W.
whitehillbilly
Reply #7 on: February 09, 2024, 07:52:40 pm
I have used Villiers Services in the past.
Great service to Australia.
whitehillbilly
Raymond
Reply #8 on: February 11, 2024, 02:51:34 pm
Glad we're back on line! My apologies for post not relevant to the thread, but I didn't think it worthwhile starting a new thread.
I couldn't make any connection with this forum late last night and again today - made a few attempts, same server unavailable error message. I assumed it would come back later. Does this happen from time to time? Has it ever happened before?
In the garage:
AzCal Retred
  • Chennai Wrencher
Reply #9 on: February 11, 2024, 03:38:19 pm
Same here. Usually there is "site maintenance" on the occasional Sunday, maybe this time things went sideways?
Ölfield
  • Enfield India 350cc Bj. 1979
Reply #10 on: February 15, 2024, 09:24:37 pm
Villiers Services
Highly recommend.
Relining takes about four weeks.
Fits right out of the box and needs little bedding in by normal use.
« Last Edit: February 15, 2024, 09:28:03 pm by Ölfield »
stinkwheel
Reply #11 on: February 15, 2024, 10:14:54 pm
My local motor factors did them in 3 days and that was only because they has to be sent off to be bonded on. They do rivett-on same day.
https://www.kandsmckenzieltd.co.uk/services/brake-re-lining/
Ölfield
Reply #12 on: February 16, 2024, 12:53:51 pm
My experiences are just for the single lever front brake model. Villiers pads made the brake useful the first time.
Adrian II
Reply #13 on: February 16, 2024, 03:34:56 pm
I'm not sure the 6" single-sided front brake was that safe in 1949, let alone in Indian or modern European traffic! however the double-sided 6" front brake which came after it could be persuaded to work very nicely.
A.
Ölfield
Reply #14 on: February 16, 2024, 05:48:42 pm
Adrian, you are absolutely right.
I could not get any sufficient braking power out of my single sided single lever front brake and I really would call it dangerous. As I needed some spare parts for my Villiers type S25 cab (79 Indian Bullet) I gave Villiers Services a try and they did very well. I love the look of the single brake and now I can leave it as it is.
The brake has lot more power and can be used much more precisely. Brake pads are from a woven material and I will find out how long they last.
« Last Edit: February 16, 2024, 05:53:31 pm by Ölfield »
