Royal Enfield Motorcycles => Bullet with the UCE engine => Topic started by: exiledcarper on April 13, 2009, 07:47:42 pm
Apologies if this has been covered before, but will the overall gear ratio be lower on the C5, with it's smaller wheels, or does it have a bigger c/shaft sprocket to compensate?
Bottom line, will the two bikes cruise at the same rpm's in top gear, at a given speed?
I've read that the C5 has a one tooth larger front sprocket than the G5, I can't remember where I read it though.
This is true, but the C-5 has 18 inch wheels instead of 19 inch wiht the G-5. I am SURE that someone here will do the requisite math.
