Thanks folks. All replies make good points and there are some good suggestions. The cable is fine and the throttle snaps shut, and the slide returns properly to the stop with the engine not running. Sometimes, with the engine running, I don’t get a nice, sharp return to idle. Now, a long time ago on Beezer with an Amal monoblock, I had a similar prob - it turned out that the slide was binding a tad due to the pressure drop across it. Before I had the opportunity to refund’ the carb’ I fitted a slightly stronger spring which overcame the ‘stiction’. H’s should have new springs available in a few months and I can wait until then. 🤞
