Do these fit a 2022 Continental GT 650?
Thanks all!
Deryl
Sorry to say - if you ask that, you may have problems to mount them. It is quite difficult to remove the inserts (bar end weights). I would go for mirrors that can be mounted without removing the inserts. Mine is the black one, the inserts are not touched at all, as you can see. You only have to unmount the cap with an allen key (while fixing the cap with a wrench), apply the mirror over the plastic ring (i had to sand down the ring a little), tighten the mirror, remount the cap, done. And the steering bars do not get wider as they are.
