So you are saying that premium gasoline is not good for the classic?
I usually put premium because o don't have much time to ride and the gasoline stays one or two months there and I thought that was better to use premium
I was also thinking of buying a fuel additives because of that
There is no harm to your engine using premium fuel, when it is not required. The only harm is to your wallet. Premium fuel,
if it contains no ethanol, will last up to 6 months before it begins to degrade. Ethanol laced fuel is typically good for up to 3 months before degradation begins, because of the water content of the ethanol.
In your case, I would not worry about using either premium, or fuel stabilizers, since you appear to use the bike more often than every 3 months.
In the case of owners who store their bikes over a stretch of winter, maybe 5 or 6 months, running the tank near empty on a final ride and then filling up with a non ethanol premium fuel would be a good idea, or, fill up with your usual ethanol grade fuel and use a fuel stabilizer.
I prefer the no ethanol premium fill up over the 6 months my bike is usually sitting, just to be sure no water can separate out of the regular ethanol blend to cause rust in the fuel tank.
