Hi having tried everything,I still cannot get rid of clutch drag completely,if I come to a halt whilst still in gear I cannot get it to change gear at all,or go into neutral,I have replaced the clutch drum/facing plate with the best second hand item I could find,I have changed all the plates and carefully filed all the tangs to remove any sharp edges, changed the cable and loads of other work,but still it drags.Does anyone have any experience of Hitchcocks new clutch drum/ facing plate,I know it is a lot of money but if it sorts the problem it would be worth considering.
Any advice most welcome. Colin
